1 - 20 of 37 Posts
What is the best place to buy front wheel bearings? How hard is it to change them? I already have ball joints, and brakes imma goona to change everything while im in there. The bearings are toast.
Discussion Starter · #2 ·
how many bearings is there up front?
4 of them ... and I had the bearing numbers ... but cant find them ... it wasnt a Polaris number , but a better sealed replacement number for 09 and earlier!
I will look for it tomorrow!!
If you need them fast there is a shop in Idaho that keeps them in stock.
I can look up the name tomorrow off my reciept.
Polaris #3514583 $30.52 2 per assembly needed ... correct me if I am wrong?
Owens Cycles in WA ...talk to Joush .... he gives deals to RZR forum members ... (509) 575-1916
Discussion Starter · #8 ·
ok thanks cwspfx. Are the aftermarket ones any better?
In the swamp.
Whatever you do make sure you take the time to repack the new bearings with a high quility grease. they will last a lot long that way.
Discussion Starter · #11 ·
I wonder is American Star bearing and tire rod ends are any good they have good prices they are on ebay.Anybody ever tried them?
???? It's a one piece sealed bearing in each hub.
Discussion Starter · #15 ·
I ordered the ones from ebay for $53. I plan on installing them this weekend, I will elt you know how they turn out. The bearings are actually KML bearings which a few people told me were good so who knows.
does anyone have the part number off of the actual bearing so i can call a local dealer in town and see if they have them in stock?
Are the front and rear wheel bearings a press fit in the Carrier/Knuckle? Have never had my 09 apart to fix a bearing(yet) and I know my days are numbered.
Thanks
yes, I used a hammer and a socket to punch them out. just use a socket or something that is the right diameter to hit the outside ring of the bearing, so you don't damage the race.
1 - 20 of 37 Posts
