1 - 2 of 2 Posts
Just received my TS bench and having a few snags. The first is I assume using the factory belts are out the question? Fishing the buckles from the bottom isn't possible.
Next is the seat frame appears to be to wide to reuse the side protection bars. I can get one side on but the other seems impossible.
Any help?
Factory belts can not be utilized on the front bench. They do not come up far enough through the bench. We as do many other manufacturers sell latch and link racing style harnesses. As for the side bars, we have found that there is quite a bit of variance in the width between these bars from the factory. For those utilizing factory cages and doors, we suggest pulling the bars outward a bit to create the necessary gap. They move surprisingly easy. Call us if you need any help with anything.
1 - 2 of 2 Posts
