1 - 3 of 3 Posts
My front and rear axles are loose at the differentials. I have taken both apart and check everything and put new seals in front and rear. Still loose and the rear diff leaks at the seal point were the axle meats the seal. Can't figure it out. Rear only leaks when I ride. Fronts are looser than the rear almost scary loose. 2008 RZR 2.5 lift with 30" superatv.com tires. Just want to ride this thing and not work on it. Let me know if you have any ideas:popcorn:
Don't know if this will help you but I just went through this w/ an 87 Dodge Charger! Oil leaking from the CV shaft seal at the transaxle, shaft sloppy loose, and if I pushed upward oil ran out freely. Took the transaxle apart and the side gears and spiders were sloppy. They looked ok but were loose. Replaced the side and spider gears as well as the spider gear pin. Tightned right up. Slop and leak gone.
1 - 3 of 3 Posts
