1 - 11 of 11 Posts
I do mainly highway/county road driving and it chews up the front tires fairly bad after I installed the lift. Do any of you know of a way to get rid of the negative camber that the lifts add?
Aftermarket a-arms. Super ATV has them and they are reasonable. The top ball joint is adjustable to correct the camber. I know they have the ones that put the wheels forward 1.5" call them to check on other options.
I modified a set of front upper A-arms to make them caster and camper ajustable. If interested I'll see if I still have pics on camera.
Banned
Yep, super atv has them and if you dont want the 1.5" ofrward, I think American star has them for stock as well.
Yeah man I'd love to see the pics of them modified, Super atv ones would be worth it cause tires are expensive LOL!
Send me your address and I can send it to you. I don't see where I can post the pic unless its on the net. I have it on my puter but not the net.
I don't see any reason they won't hold up as I used 1/2" rod. I just did it last week and only put about 10 miles on it this last weekend with no problems. Most all the pressure is on the outer end of the A-arm from shock out to ball joint and thats not changed in any way.
1 - 11 of 11 Posts
