1 - 5 of 5 Posts
Hey Guys.
Tried looking for similar posts but havent found any yet.
Just picked up a used 2011 Rzr Xp. Checked it over good & didnt see any issues untill first ride out. I running a set a 28" Zillas, no lift and now found that the drivers side tire hits the fender under compression. I mearsured C-C of rims & have 82.5" on passengers side & 81" on driver side. So drivers side is pushed back 1.5"
Frame looks good, all mounts look good, A Arms look good. What is the problem???
Discussion Starter #2
Pressured washed the machine & checked it all out again. It ended up being a bent A Arm.
Now the worst is no stock available for 4-6 wks locally. Checking on the best way to go next. Lift kit & arms or just Clearance arms???
Also check the frame to see if any of the powder coat is cracked.....had the same issue bent a arm but also bent the frame a bit. On another note I have a set of a arms for a 900 where are you located just took them off
ahhhh Cold Lake , I'm in Red Deer
1 - 5 of 5 Posts
