1 - 4 of 4 Posts
Is it ok to drive the 2012 900 xp with out the front drive shaft installed? Drive in 2 wheel drive and ride like normal?
Thanks alot! my center support shaft bearing went and i still wanna ride it till it arrives just wanted to make sure thank you!!
Not sure about XP machines, but be sure to use a punch close to the size of the roll pin through the front yoke. Then clean up the ends with a flat file before reinstallation.
Just a thought
Pirate
1 - 4 of 4 Posts
