Front diff problems
2.2K views 7 replies 4 participants last post by  Kandgo
I was putting a new roller cage in my 08 rzr front diff, I was taking the axles out and got the first one out, then I couldnt get the other side out. Having never done this before I looked inside the diff from the side I already pulled out and tapped what I thought was the end of the axle until it broke! That when I new that this was not the end of the axle.
What have I broke?
Is it something that needs to be replaced? If so what would the cost be?
Thanks,
matt
#2 · (Edited)
Matt, unfortunately that was not the stuck axle you were hitting....short answer...yes, you'll need to replace the piece. I know there was someone that did the exact same thing and posted about it a while ago....and in his case, I want to say he went the route of using JB Weld as I think he had only cracked his. Not sure, but I'll look for the thread.
Personally, I'd replace the broken parts and not worry about a repair holding.
Almost forgot....the name of the part that you broke is the output hub assembly.....around $225
