FYI,
My pinion bearing never had any slop even with metal bearing cage torn out. Metal cage bearing is bad idea for the pinion. Too much flex under load for such design. Output hub bearings seem to be fine with metal cage. However, the upgraded Sandcraft units had more metal balls and thicker race with more surface area for side loads.
The parts I think matter most are in this order:
- SKF Pinion bearing with Phenolic resin cage
- Grey seal in Sandcraft kit seems more robust, higher silicone like material
- Metal pin in kit is much stronger, my OEM pin was slightly bent
- Must fix the output hub plugs that leak or upgrade to newer design $$$$
If you have as much metal on your magnetic plug like I did you may need a new sprag assembly. I got away with H springs. Had some history marks and broken spring. Everything else was serviceable.
Post up your results. Need to share info on such issues.
If you find something better than the Sandcraft bearing kit please share that!
SKF Explorer Bearing from Sandcraft has Phenolic resin
Cage.
From SKF:
This material can withstand heavy inertial forces and operating temperatures up to 120 °C (250 °F). ... Cotton fabric reinforced
phenolic resin is the standard
cage material for most super-precision angular contact ball
bearings.
