1 - 5 of 5 Posts
It seems as my front diff is stuck in 4wd . We have undone the wiring. you can roll the car forward but not backwards if you put the car on stands you can spin the front tires forward but not backward. Has anyone had this issue ?
Doesn't sound like it's locked in 4wd. sounds more like something is broke in the front diff. or the tranny or transfer case. If it was just locked in 4wd you would be able to either drive it in reverse or roll it backwards in neutral no problem. Seems like it's time to remove the front drive shaft then try turning the front wheels forward and backwards, if it works then you have a problem in the tranny or transfer case, if it fails the problem is in the front diff.
Mike
Are you saying the front tires will free spin forward but not backward on jack stands? Or you saying the machine will not reverse?
Discussion Starter · #4 ·
They wont free spin backwards on jack stands. but they will spin forward. Reverse works fine. Its like its stuck in 4wd
1 - 5 of 5 Posts
