1 - 8 of 8 Posts
I have a 2015 rzr xp1000 when I put it in 4 wheel drive there is a hard vibration. I have replaced all the axels, complete drive shaft, front diff, carrier bearing, running out of money don’t know what the next step would be, any suggestions? From the transmission up is all brand new.
Did they ship everything assembled? Seems like it would be to long for shipping. Did you make sure to match drive shafts up with balance/alignment marks. They are usually just a grease pen mark on each part indicating all parts should have mark on same line when installed. If not then your drive line would not be balanced.
Check wheel bearings for play. I had a similar issue and turns out my front wheel bearings were sloppy. I only had vibration while in 4wd and actually was engaged
1 - 8 of 8 Posts
