1 - 3 of 3 Posts
Need some help. Was driving our RZR and a loud banging noise came from the rear end then the axles locked up. Would not go forward, even in neutral I could roll it. Tried reverse, it will drive fine. In neutral I can push it backwards. As soon as I try forward it goes about 4-5 feet then locks up again. Neutral locks up as well. Reverse still fine. Any ideas I’m at a loss.
Yessir, time to pull that gearcase out, sounds like the shift cogs/forks and gear selection shaft has probably broke into numerous pieces.
1 - 3 of 3 Posts
