1 - 5 of 5 Posts
Going to change the fluids in my new 2017 XP1000 this weekend. Picked up two quarts of Polaris AGL for rear diff and quart of Drive Demand Fluid for the front diff. Did the engine oil and filter already.
What else do i need? Unit has only 65 miles, but sat for almost 2 years.
Any tips appreciated.
That has the fluids covered. I would probably drain the fuel and start fresh there.
Pull your air filter and vacuum it out good.
Then grease everything.
Next, go enjoy that thing. You've got a lot of miles to make up for!
The Lone Rzr
2 year old brand new machine? Sounds like it made it to the right home.
I'm meticulous with my fluid changes but I would put at least a few hundred miles on it before changing the trans fluid. Give the gears time to break in. It's not a cheap oil change either.
Front diff only takes 8oz so the quart will last a few changes.
Have fun!
Some ppl use 75w90 full synthetic in the rear case including me but I'm AGL is fine just make sure you check it or change it often as the miles start to build up. I do the same thing in my trucks I own just a good safe practice.
1 - 5 of 5 Posts
