1 - 1 of 1 Posts
· Registered
This is a common question from new owners:
"What does the flashing wrench in the display cluster mean?"
It just means that you have hit the re-settable service interval (probably set at 50 hours from the factory).
You can use this as an indication of when you need to change the oil or perform preventative maintenance.
instructions can be found in the owners manual on how to reset it or turn it off.
1 - 1 of 1 Posts
