Fixing a flat on the trail
18K views 76 replies 37 participants last post by  Wheel
#1 Ā·
I have a jack and spare if needed and a compressor also your standard tire plugs with reamer and tool to install plug.
Is there anything better?
Or is this still the best way?
The Boss (aka Wife) and I ride alone 99.9% of the time. I really don't like people much 😜
Except on this Forum!!!!
I ride mostly in low gear and on desert rocky trails.
Haven't had any flats yet just like to be prepared, TIA
#5 Ā·
The first defense is the tire itself. Run a tire designed for rocks, If that is what you run in. My goal is to get it fixed enough to get back to camp. Keep spare tire in camp. Only place I have had flats in Utah's rocky trails. Some of there rock is as sharp as a knife. Once tire has gone down, I do not what to take off for deep back county with it again, even with other machines along.
#9 Ā·
Haven't had any flats yet just like to be prepared.
On my first ride (within 10 miles) of getting my new RZR I got a tire pierced by a piece of wood the size of a pencil. No tools, no spare tire, no nothing. Made it back before tire went flat. I learned a lesson on that first trip.
I now carry EVERYHING, spare tire, tire puncture kit, air compressor, jack, tools, spare belt, UHF/VHF radio, water (AZ desert) and even considering one of those satellite communication devices. I'm pushing 70 so ALL that stuff goes with me everytime I go on a ride. No matter how short or long the ride is.
#14 Ā·
Have run rangers in Alaska and RZR in Az for 20 years combined. Our group has had a few flats, 1 time in Alaska, 6ā€ sidewall, many plugs later, tire held up the rest of week in hunting camp. 3ā€ sidewall in Az. And with plugs finished the 80 mile trip. My opinion is carrying a spare does make it a little more top heavy, so we leave our spares. Anyone ever use the sidewall plug?
#15 Ā·
I carry, 30 plugs and kit, a sidewall slug, a Colby Valve emergency valve stem, a valve stem remover, a can of either about a third of the way full wrapped in foam inside a small tool bag inside my bottom ridged box, a long stem lighter, a small bottle jack and a tire pump. Spares are at camp.
#18 Ā·
I’ve had two major flats the first one with the tire plugs left me stranded in the picture they would not Seal flat tire ,Second major flat
663944
ti had spare tire save the day.
Not my first barbecue ,fixed the fixable with tire plugs but sometimes they don’t work.
#19 Ā·
Go and get couple of the bulk pack of plugs. It amazing how big of cut in a tire you can plug long enough to get back to camp. I should have taken some pictures but this summer had to use a fist full of plugs on a pinch flat that left a 3 inch cut. It made it back about 8 miles to camp. Took maybe 5 minutes to plug and get moving again.
#23 Ā·
I'll chime in for fun.
Buddy I ride with abuses tires, he is a binary driver. On the gas or off, no happy medium. His best score is 40 plugs in one sidewall hole. Rubber cement, plugs and a lighter proved that you can get em home. (Other high score is less than 24 hours before trashing a new set of tires)
The ratchet strap method for off the bead.... It works great on softer tires, 32" DOT approved, not so much. Finally had to grab the can of starting fluid and "safely" pop them back on bead by fire.
#29 Ā·
It’s usually not too hard to find a close spot to get a tire off the ground if you don’t have a jack.
I guess you have to do what you have to to get back. I just carry a spare in my bed but i also have a plug kit. I’m not putting a handful of plugs in a tire, I’ll just swap it.
knock on wood, I haven’t gotten any punctures yet.
the guys we ride with drive like maniacs, only 1 puncture on a pos tire all season... not sure where you guys are located or ride causing these.
