1 - 7 of 7 Posts
Any pics or specs?
RZR Plus 6 Long Travel Kit
Walker Evan remote reservoir 16 way adjustable Billet aluminum reservoir mounts Axles - XMF 4340 Heat Treated center less ground and powder coated Uses OEM sway bar, includes new links 1/2” Chromalloy FK Teflon coated steering heim joints with billet aluminum steering extenders and zinc plated hardware Arm Construction - 1 ¼” 4130 chromoly tubing X .120 wall thickness TIG welded for strength and appearance Front Arms- Lower- uses spindle adapter and unibal Upper uses a ¾ FK Chromalloy Teflon coated heim joint with a adapter to connect to the stock spindle with out any drilling. The dapter is constructed of Chromalloy steel which is heat treated and black oxide for strength and appearance. Rear Arms – uses tube cups with CNC washer TIG welded for strength to attach hubs to arm which provides a much stronger connection than using tabs. All arms use grease able Delron bushings and crush tubes on the chassis side New brake line for front left side Powder coated finish. Comes with lifetime warranty against manufacture defects.
I think its a plus 6 that would make your rzr 12" wider. if you ever ride LT you'll never go back to the old wagon on a rock road feel.
Is the front hiem joint or ball joint and does the 4th axle come with it since its not pictured. LOL kidding about the axle.
PM a Price PLEASE
1 - 7 of 7 Posts
