Constructed from 1 1/4 inch chromoly steel tubing and CNC machined ¼ inch high tensile steel axle holders. Mounts using Black Max Teflon lined 15,000 lb chromoly heim rod ends that can be adjusted for an extra 2 inches in length if desired. Powdercoated for a tough long lasting finish, this kit comes complete with custom molded UHMW skid plate. This setup will put the RZR 170 broken arm issues to rest once and for all. Don't waste your money on the junk oem replacement. $449 retail, $429 Forum Member's.
