Mounted Rotopax under Polaris tire carrier. It holds 2 x 2gallon tanks, pics only show 1
As an aside, I could not find any place to install my 2 gallon fuel Pac on my 2020 Pro XP 4. I wanted to stay away from any heat that was produced by the engine. My scissors jack and fire extinguisher did not allow me room to mount on the rear roll cage bars. Thanks for sharing. I will do the same.
Behind the passenger seat (it has to be adjusted to the front location), very convenient location no need to move it to fill it up at the petrol station and easy to transfer petrol to the RZR main tank with a hose a manual pump.The one I used is a Fuelpax (3,5 Gal/13,25 liters)
That would work for me, but my diabolical friends would be sure to scare the hell out of my wife with stories of fiery crashes!![]()
Does the Roto Pax latch system bolt on underneath the tire rack or did you have to do some additional modifications to make this work?Mounted Rotopax under Polaris tire carrier. It holds 2 x 2gallon tanks, pics only show 1
Standard Rotopax mount kitDoes the Roto Pax latch system bolt on underneath the tire rack or did you have to do some additional modifications to make this work?
Thanks
Ohh that's a nice spot!
Does anyone have any pictures of extra Fuel storage on the Pro XP?
Did you use a rotopax mount? If so which one? and what size can is that?Behind the passenger seat (it has to be adjusted to the front location), very convenient location no need to move it to fill it up at the petrol station and easy to transfer petrol to the RZR main tank with a hose a manual pump.The one I used is a Fuelpax (3,5 Gal/13,25 liters) View attachment 671179 View attachment 671179
I like the location! Can you share a picture of how you mounted the rotopax? Is that the 2gal? Thanks!!Ohh that's a nice spot!
