I just finished doing pinion nut repair on my 2012 RZR 800, replaced all the wheel bearings and put on new tie rod ends, and before I re-install the bed I wanted to complete a few other items.
My unit has 250 hours and about 1500 miles and I bought it one month ago.
I wrapped the exhaust pipe with DEI exhaust wrap from the headers to the muffler.
I replaced the existing spark plugs with NGK BKR7EIX Iridium plugs.
I pulled the Pressure Relief Valve, it was clean, buffed the pin with Scotch Brite and reinstalled with the chamfered end of the dowel pin down.
I started up the engine with the panel over the CV belts off and the bed is off. I didn't notice this before, but there's more noise than I remember coming from the engine.
At idle, I put a long screw driver to my ear and I can hear the valves, they're loud, but it's not pecking, and I hear the sound from other areas of the engine, but not as loud.
Is this normal for this engine ?
I had a '93 Jeep Cherokee that had the 4.0 liter straight six and the top of that engine sounded like a loud sewing machine.
I just want to be sure I don't have a problem before I start trail riding. I'd hate to pull the valve cover, but thought about removing the assembly, that has the hose going to the air filter canister, on the valve cover to see if I could see oil getting up there.
Any advice ? Thanks
Any advice ? Thanks
