1 - 2 of 2 Posts
I have an 09 800, has about 9000 miles on it. Last nite on a ride after dark I notced that my lights would dim a bit and my engine would also miss and sputter, almost like running on one cylinder, after a short time it would return to normal but it did that several times. I have a new battery, the rzr does have a radio and 2 other additional headlights. Could this maybe be a voltage regulator problem? Any help would be appreciated.
Could be the regulator. Start with pulling all the terminations off the common ground on the frame behind the driver's seat. In spite of how they look, clean all terminals and the grounding post with wire brush and spray them with a good grease or terminal anti-corrosion spray and re-torque. A faulty ground is a common issue and is a good place to start your troubleshoot.
1 - 2 of 2 Posts
