1 - 5 of 5 Posts
I’ve been having problems with my 2017 S1000 cutting out & the check engine light has been coming on. Finally got it cleaned up so I can try to figure this out, but I’m getting a code that I just can’t seem to find info on.
Can anyone help me figure out what 520308 is?
Thanks in advance
My check engine lamp blinks when displaying codes, which manual says is a engine fault code. The FMI # is 31, the SPN# is 1127. The owners manual does not show SPN # 1127. How do find SPN numbers not listed in manual?
Boost Pressure Sensor Condition
This code could be caused by an over boost condition. There may be an issue with boost pressure sensor wiring, or turbo waste gate. Check all applicable hoses and wiring.
Thank you for pointing me in the right direction. After posting this I researched further and came up with the same diagnoses, over or under boost. Thanks again for your reply.
1 - 5 of 5 Posts
