1 - 4 of 4 Posts
Anyone running an Eibach Stage 2 spring kit on a 2 seat Velocity with stock valving? Trying to smooth out the lower speed chop, bucking and roughness.
I have my shocks being worked on as we speak on my 4 seat velocity. The springs alone will be a massive upgrade from stock and then a valving on top of that will equally outperform the shocks with the new springs. The springs alone will absolutely be worth it to help remedy the issues you are having, but if you can swing it, go with the valving as well.
Thanks for the reply Gonzanc. So your springs are Eibach stage 2? And who is redoing your valving?
I am not sure what stage 2 identifies, but they are eibach dual rate springs. Ed the Suspension guy is doing the work (PoundSand)
1 - 4 of 4 Posts
