1 - 3 of 3 Posts
Something worth getting done? Reading old posts and hasn't really been discussed on here for over a year, just wondering if there's a better way and that's why or what?
to do what? reflash the ecu?
If you want to change the fuel map, timing curve, and rpm limit I would use external programmers so you could adjust it. reflash is a one time deal and you are stuck with the new program.
The Dynatek ignition module and software can modify the timing and rpm limit.
It looks like you already have a power commander for adding fuel.
Well that's what I was wondering, better to just by adjustable ignition then, and do it myself. Thanks
1 - 3 of 3 Posts
