Just wondering if anyone has made the switch ?
i am research it and for my application it looks very promising .
thanks Tim
thanks Tim
Switching from C16 racing fuel @ 9 buck a gallon to E85 ethanol @ 2.49 a gallon..Please excuse my ignorant response, but I have no clue what your talking about. lol..Please explain..opcorn:
Pulse width is the amount of time that your PCM commands your injector to deliver fuel.http://www.youtube.com/watch?v=24v5gzSJ6N8
i thought some one would of converta to it by now
E85 Conversion Kits Change2E85.com
I think i am going in this direction !!!
lower engen temps , able to run more boost , 2.49 a gallon ..
lots of injector stuff to learn I.E. what the heck is pulse width ?
Tim
is this on a rzr ?I switched over to e85 when i built my turbo kit. it takes about %30 percent more fuel, not only is it cheaper you will pick up 3 to 5hp
it's on a 09LE rzr I'm running 12psi/ I have stock injectors with a split second inj controller with 2 60lb injectors I went to a 190lph intank pump from mpi and converted to a return style fuel sytem with a aeromotive regulator. here is some pics their from my phone so their not the greatestis this on a rzr ?I switched over to e85 when i built my turbo kit. it takes about %30 percent more fuel, not only is it cheaper you will pick up 3 to 5hp
Do you have any pictures ?
how much boost are you running ?
Thanks Tim
Thanks Tim
I have ran it around the house and one trip to little sahara oklahoma to tune it but am going for to days this weekend have not dynoed this yet we did a teryx at the same time on e85 with 16 psi and it made 93 to the wheels.it's on a 09LE rzr I'm running 12psi/ I have stock injectors with a split second inj controller with 2 60lb injectors I went to a 190lph intank pump from mpi and converted to a return style fuel sytem with a aeromotive regulator. here is some pics their from my phone so their not the greatestis this on a rzr ?
Thanks Tim
Looks Nice !!!
have you ran it much and what kind of H.P you maken ?
the thanks for all input .
if you are ever in glamis look me up , i would love to check out your ride.
Tim
Looks Nice !!!
Tim
