21 - 31 of 31 Posts
LOL, now that you point out and i put my glasses on I see that it is the stock deck. I do notice the carbon build up along certain edges. My understanding is that those are hot spots due to the sharp edge. Chamfering that edge will take away the hot spot and create a more even burn. Is that true?
Did the flow test the head before and after?
Tom
Discussion Starter #25
Tom
He did, but since both cylinders share the intake port the test didn't really show the true gains. He had to weld up a little divider in the middle to actually be able to test it. I know that this caused a lot of excess turbulence and didn't account for the true flow of the head. Even with the divider I remember that the head picked a surprising amount of cfm!
I have the flow chart filed away somewhere...I will try and dig it up :)
This is the most that I have ever seen a head opened up. On most, I can still see some of the casting marks, and none never come so close, much less remove material around the valve guides. Although I can't see much from the photo, I have not seen any others clean up the exhaust side, because it is so tight. Obviously opening the head up, no matter how much, it will move more CFMs. I understand that it is hard to get a true number on the flow bench, but my concern would be the turbulence. How can you tell that both sides flow the same? I went to the web site, and signed up, but I could find nothing about porting the RZR.
The stage 3 head with 1mm over sized valves and full port work flows nearly 40% more then it does stock.
Making them flow the same is not that hard at all.
And also in stock form because of casting flaws, and core shift the heads new out of the box don't flow exactly the same on both sides.
Matt, did you ever figure out what it would cost for the port work... and do you just open the intake or do you also polish the exhaust side?
Thanks
Thanks
For a heads with Stock valves and stock springs but with full port work would be $699 that's with new seals ect.
Discussion Starter #31
Thanks
That's a great price considering the gains and that the seals alone are $42!
21 - 31 of 31 Posts
