1 - 9 of 9 Posts
So as I am wrapping up the rzr build. My question is how or where do i mount the amp for the duner tunes kit I bought off of another member. I think he said it mounted on top of the steering column, but I have my boost / AFR gauges right in that area. so how do I pull off my front plastics to see if this is gonna work. Or does anyone have another idea where to mount it? Thanks for your help in advance.
Looking for a way so that I do not have to remove the cage and plastics at this time.
No need to remove cage/plastic, cut out to pieces of alum. mock them up drill holes and your good to go. VUALA then you wait for beer thirty
I am in it to win it with that theory! Gonna try an run to pismo for a day run on sunday!
out under the front hood .:)
Discussion Starter · #7 ·
Can't go there as I have the heat exchanger under the hood. Looks like a tight squeeze
Discussion Starter · #9 ·
Gonna just fab up some mounts for under the dash since I don't want to pull everything apart again. I don't even care about tunes right now.
1 - 9 of 9 Posts
