1 - 5 of 5 Posts
The Beast
Does anyone have dual muzzy's mounted with a lift?
Does the lift get in the way of the pipes?
I have this setup. You'll need the Racer Tech Muzzy 2" lift kit. It is laser cut to allow room for the pipes, and looks awesome.
i got my lift off ebay and had to do some fab work on the lift a lot of cutting and welding i wouldnt do it again but already had the lift and wanted the pipes
I've got Roktech lift off of ebay installed with my Muzzys. I bought the lift before I had the exhaust. I did have to modify the lift to install the exhaust. Wasn't a big deal just marked and cut out for the pipes then welded some flat bar to reinforce where I made the cuts. If your buying a lift getting one that already works the the exhaust isn't a bad idea. I only paid 135 for my lift.. Took about 2 dollars worth of flat bar to mod it..
Here is a picture of where the cans hit.
1 - 5 of 5 Posts
