1 - 6 of 6 Posts
What are exactly the tools needed for drive belt replacement?
From what i can tell you need a screw type handle tool. and some other odd looking tool that goes into the flywheel.
Then i saw another larger style that screws onto the outside?
any advise would be great.!
thanks
Super Moderator
8mm socket and drive of choice. I use an extension on my impact wrench. And to loosen the secondary your machine should have come with a L shaped threaded tool. It screws into the secondary to spread it open. Takes less than 5min to change a belt.
Thanks.
the 8mm socket is to remove the cover or somethign else? and the L shaped tool is supplied, ok got it. thanks for the info.
lots of videos out there ....
1 - 6 of 6 Posts
