I have a Drift HD camera that I use on my RZR, it gets dusty but not wet, It has started to "freeze up" when I record with it for extended periods, If I start a recording while riding (it is mounted on my windshield bars) it will be frozen in record mode when I go to stop the recording, the display will be blacked out and it won't stop or turn off, the only way you can do anything is to remove the battery, this loses the recording. Once you put the battery back in it seems to work ok again, I have reset everything back to factory settings, re formatted the SD card. I contacted Drift and they werent able to do anything, said it was probably caused by vibration, it is out of the warranty. Has anyone else had issues with a DRift HD camera? Now I want a new camera, I really like the GPS part of the Contour GPS, but it seems to be discontinued or Im reading wrong. Maybe a GoPro is the best bet?
