If u run them i suggest bead lock rims. Do not run stock rims. The rear tire will flex and rub on the inside. I damaged a tire by doing this. It ended up making 5 fist size bubbles in the side walls.
Interesting. I had a set on my Commander (when I had one) and the same bubbling thing happened but I literally had them on for about an hour when I noticed it so took them off. I thought it was a MFG defect...
Anyway, I went with Skat's on the rear and the Doonz on the front and love it.
I've had my Doonz for almost 2 years and no issues with bubbling. I run them at 5-6psi and no problems at all.
Any issue with the Scats on the rear, 26" tire, and the Doonz on the front, 25.5" tire. I worry that if I run in 4wd, which i don't much, it may brake something.
