21 - 28 of 28 Posts
where is this infamous fuel vent line located, and run to???
Comes from the sending unit runs to the drvers side and up into the frame on the drivers side right where your engine cover locks
need some help with this, searched and seen you can pump air into it to get it back to form but where do i hook the air to?
just sucked my gas tank up, what is the best way to get the dents out
Make sure everything is fine with the vent...
You can try to "pop" it out by putting some pressure into the tank.
Discussion Starter #28
The return, vent pipe... The other one to the fuel line... You only need to fart at it and it will pop back out...
21 - 28 of 28 Posts
