1 - 4 of 4 Posts
AKA: blinginvic
Can I double up with the washer type weights on the Dirty Dawg Performance Clutch Kit arms? I was thinking one thick and one thin per side. I'm trying to get 10 grams on the heel.
Is the liquid in the tube essentially the same as Loctite blue?
Thanxs
AKA: blinginvic
Discussion Starter · #4 ·
Thanxs Jeff. I appreciate it.
I did find out though, that if you double up on washer weights, you have to ensure the flyweight will have full travel. After I put the weight I wanted on the tip and installed the arm back in, the added width of the weights would not allow the arm full travel. I had to change the configuration of the tip weights.
Quick tip...run a male thread tap through the arms weight threads to remove any built up thread locker....makes threading in the weights much easier!
1 - 4 of 4 Posts
