1 - 8 of 8 Posts
dirty dog clutch kit off a 2010 s fully adj to what you want i have a normal helix and one for engine braking everything in pic is included SOLD
super atv 2inch wheel spacers one full set SOLD
Discussion Starter · #2 ·
will fit on 2009 built after 10-08 and 2010-2012 rzr rzrs and rzr 4
why does the one weight have less than the other 2 and are both helixes the same
just no engine brake and what driven spring is in side. i have a 10 and looking for my sand set up
Discussion Starter · #4 ·
They are the same that's what the other side looks like
Green spring in it the helix are same just one with engine brake for trails with more hills
Discussion Starter · #7 ·
I had it set for crawling at first but changed it to have more top end was running 30s when i first got it then got 27 pit bulls you can adjust it to what ever you want really easy i have all the weights marked and a scale that i will give you. Each person will have to adjust it to there rzr no one is the same. when you adjust the weights all must be exactly the same in the same slots
1 - 8 of 8 Posts
