CVT engagement question
1 reading
2.5K views 4 replies 5 participants last post by  dafish
Hi all,
I am thinking about checking out a 2015 rzr 900s. I checked out a maverick 1000 today and the cvt engagement didnt feel right. Im pretty sure its boned, but i wish id done more research so id known what to look for when i checked it out. In that vein:
How smooth should it be as i apply throttle? (the can am was jerky unless i gave it a lot of rpm)
Whats a typical engagement point RPM wise?
I had an older Trailboss and trailblazer back in the day, should it feel similar to that?
So much depends on so many variables. A perfect system will have a smooth engagement. When one is talking used then.....well it gets complicated. What kind of condition is the belt? Does it have flat spots? Is the clutch full of dust and dirt? Would not totally judge a used machine by engagement. More on the condition of the overall machine. Engagement can be or might not be an indicate of how machine was used. Without pulling the cover and doing an inspection it is very hard to tell a lot. If looking for a good engagement, purchase a new one with a warranty. All used are a risk and will have issue one has to work through. Very, very few will behave as a new one will.
Stock belt on the 2015 ALWAYS had a jerky engagement. Loading it onto a trailer was always a PITA. Call @Hunterworks and ask about a fix.
Check the New Owner FAQ at the top of the forum. New Owner must do's / FAQ / Alerts
Also,
Thoughts:
  1. Buy as much machine as you can, in as good a condition as you can.
  2. Don't buy a '16 Turbo.
  3. I have a life-long friend with a '15 Maverick 1000r. It looks and sounds great! He sure has helped sell a lot of Polaris machines. Run Forrest run!
    1. Poor ground clearance
    2. Poor front diff engagement vs Poo's
    3. Not really very fast
    4. PITA to work on. (kind of a mid-engine thing)
  4. Sooner or later most guys end up needing a dealer. I would ask around about quality service options in my area.
  5. Clutch: It's like any other cluthed machine - You don't want to stay partially engaged. As engagement occurs roll into the throttle smoothly and let it transition. If you don't it will buck, and that's your clue that you aren't being aggressive enough. But you should not need to feel like you need to stab it.
  6. I do think the Poo 900 and the maverick 1000 are relative competitors, while the poo 1000XP is better than either in most every way.
  7. I would try to find an XP1000 with fox shock if you can afford it. The only better buy in SxS is an '18 XPT.
