I have a 2014-800XC. Ran great for a long time, Years. This year. Year six.... I was just cruising along at a slow speed taking my time, enjoying not being in a hurry... and the RZR began to bog out. Loss of power. . If I turned the key off. Then I’d turn the key back on... I’d hear the fuel pump prime and the RZR would start immediately up, as if nothing was wrong. I could venture another mile or so and then bog out again. So on and so forth. This was perplexing. I thought it was the fuel pump. Long story made short... eventually after troubleshooting the plugs, the fuses, the gas cap, the wiring, all the tests on the fuel pump for pressure etc....I pulled my pump cleaned off the only thing I could see that I could..., The mother board for the gas gauge...then.. I stuck it back in the fuel tank and carefully aligned it to the rear of the RZR with the cute little arrows and for some weird reason, I can’t explain... the bogging out stopped. All that I noticed that appeared to be the problem... was my seal on the main fuel pump... the ring that a person twists... on the top of the tank... must have been leaking. I tightened it firmly — beyond where I had carefully marked its original position...and my problem was solved. Old rubber gasket and all. So before you all pull your hair out and wallet...
If your machine dies after a warm up period... after an hour out on the trail or something similar to my experience — try tightening the darn main seal on the tank. I wish I would have. There is a lot of other stuff I could discuss on this topic that I experienced... but I’ll leave it up To you‘all to ask the questions. (I need to go back into isolation.) -socially distant*
