1 - 4 of 4 Posts
I need to cut my RZR dash to install 5 new rocker swithes. What is the best tool to use to make the cuts outs??? thanks for any help you can give me...
drill holes at the corners, then use any fine tooth saw.
I have even just used a box knife for cutting and trimming the plastic.
Rotozip works quite well if you have one.
Dremel is similar.
Otherwise, as Tuf said, drill and use a keyhole saw with a fine blade. :)
1 - 4 of 4 Posts
