1 - 13 of 13 Posts
Only 452 miles on the machine, I am not sure of the hours but not many.
Crank just failed as far as I can tell. I got a misfire code after running it in early July. Machine lost all power and went into limp mode shortly there after. Took it to the Dealer later that week and before they even looked at it they said that is was probably belt chatter that was causing the misfire code ( it wasn't ). Tested the compression and 1 cylinder tested really low. It has been at the dealer ever since and I am getting beyond frustrated. First it was the clutch recall that prevented me from using the machine for 1 spring and now this.
Thank you for the help with Brian Crown. I will look them up
1 - 13 of 13 Posts
