Save on Corbin Kits from pro UTV Parts. PM, text, or phone for your deal.
Features:
Plugs into factory wiring and connectors = NO cutting or splicing of wires.
Use your RZR factory tail lights as rear turn signals, NO drilling or adding lights to the rear of your RZR.
Bright LED Amber lights for the front of your RZR, two on each side for better visibility.
Our kit is engineered to last! Everything was designed to handle anything you put your machine through. Weather-sealed wire connectors and submersible control module.
Back-lit Rocker Control Switch: Directional arrows on control switch flash to indicate chosen direction. We use high quality Carling brand switches, only the best!
Hand-made Wire Harness made specifically for the RZR. Choose your model from drop down menu for exact fit.
Easy installation with a few tools. Detailed instructions included with kit. Full color PDF available on request.
Made in USA.
PM or Order online!
Search: 10 results found for "corbin"
Features:
Made in USA.
PM or Order online!
