21 - 40 of 42 Posts
anyone know what the color for the wire on the 2012 900xp.-- do u provide positive to the fan or do u provide ground for the fan. just want to be sure because i know polaris does their wiring in differ ways.example the taillights or even how they make the turn signal actually show up on your factory rzr dash. because i only have the manual for the 2011 xp and want to make sure it is the same and if it is i know u would provide 12 positive to the og/bk wire and obviously done thru at least a 30 amp relay using in my opinion 12ga wire but can use smaller gauge wire on the 85 and 86 terminals
X2, this is the answer I am looking for as well. I want to do my own switch and relay but just wasn't sure what wires to splice into exactly and also whether they are supposed to be positive or negative.
if i splice into something also, i do not u t-tap style connections. Thaose are the worst style of a connection to use.IMO u strip back some of the insulation then solder onto the wire then use liquid electrical tape then regular tape.
i have read those instruction and i believe them to be true- where some might be getting tripped up is on the other side of that connection are the color of the wire coming from the fan which are not shown in the polaris manual. The colors before that connection are black and blue.the black matches with the brown (which is the ground connection) and the blue matches with the orange/black wire which is the positive side
so the way i plan on wiring my fan override with a relay is as follows: a fused lead goes to terminal on 30 which is constant power, pin 87 will be attached to the blue wire that comes off the fan(these wires i suggest to be 12ga) pin 85 goes straight to anywhere u can find a good ground. 86 is going to be the control wire and will only get power to it once u flip the switch completing the circuit. you will also need to run 12+ to the switch so once u flip the switch it provide 12+ to pin 86 thus completing the electromagnetic circuit in the relay which will turn the fan on.
I hope this helps others--or i just may have confused you more
oh and if u get a standard 5 pin relay 87a pin will not be used in this situation
so if some was trying to do this with switches that look the same on your dash you can figure prices to go close as follows:
switch saying fan override-----20
relay ----------------------10-15
misc connections 5-10
wire 5-10
so as u can see buying it from utv inc does makes sense UNLESS you are like me and already have all these parts in your garage
Discussion starter · #30 ·
wire 5-10
I agree with your price qoutes joemamma, but you forgot to add $40.00 - $50.00 for shipping and customs charges for us guys in Canada.
. A big thanks you for everyone who has posted a useable reply to this thread.
ahh i see know
didnt notice u were from canada
so maybe putting the kit together yourself would be cheaper due to shipping charges
I was not putting you down. But your rambling on about pin connections and blah blah blah is only going to confuse the leyperson even more along with yourself. If you were as smart with electronics as you claim you would have unplugged your fan started your car and used an ohm meter to know what wire did what. The directions posted were straight forward and simple do not complicate, find your power source hook to relay or inline fuse, hook to switch, hook to positive side of fan, done!
and for those that are mudders or go deep in the water and want to do the opposite, turning the fan off via a switch pm me and i can help those who need it.
10 years certified Yamaha A tech, 5 Years diesel mechanic, Owner/Operator Terminal Velocity Performance, Electrical Engineer by trade.
As I said you are doing nothing but confusing people with you talk on Pins and locations most people have no idea what you are talking about. There is no mention of it in the directions in the kit. Most people who are going to attempt to do this without the kit are going to tap into the accessory wire through a relay to a switch to the fan. If they are confused about which wire is the hot wire they will use a ohm meter or even a test light to find the 12 volt powered wire. whomever told you you cannot use a ohm meter on a powered circuit needs to go back to school BTW. I can point you to switches that will handle the amperage that look like the dash switches if you like where you would not have to even run a relay. Helping out fellow RZR owners is different than confusing them or giving them bad information, even posters above told you just to buy the kit as from your posts it seemed over your head. But with your mechanical experience level we all know you got it figured out and I am sure you will have it working just fine....
Good Day!
As I said I was not trying to put you down if you felt that way I am sorry. I have found on forums you can never tell the experience level of the people you are dealing with and it is easy for us to think others know or have the experience we do. this is often not true and while good intentions are always usually made sometimes to many details make it more confusing. I try to keep things as simple as I can when explaining things and pictures work best everybody loves pictures right? The switches i seen in a catalog at work look very similar I will find them again and share the details. I chose not to use them for any of my needs I went a different route with different colored LED switches for different functions and did not want them in the middle of my dash..
i did not mean to argue with u as well or mean any disrespect either.
21 - 40 of 42 Posts
