1 - 8 of 8 Posts
Hi, need some advice. I allowed my razor to overheat from a clogged radiator and most of the coolent squirted out. I am about to change the coolent out and my question is this, is the polaris coolent diffent then the auto shop coolents other then its pre-mixed to the 60/40 ratio? Any advice would be appreciated thanks.
Old West Reenactor
I use "Liquid Ice". That's the brand name...
I used regular anti-freeze mixed at 50/50. I was going to use engine ice, but I didn't want to spend that much on anti-freeze and the regular stuff works fine for me.
I replaced mine with Engine Ice.. It works better and is non toxic..
Thanks decided to go with the engine ice. Used the manual to drain the old anti-freeze. The specs said 4.6 quarts, yet only less then 2 quarts came out. Added the engine ice and did procedure to work out air bubbles. I believer I only got out half of the old anti-freeze as it now looks like regular anti-freeze again. Any suggestions on properlly getting out All of the old antifreeze?
LoL I started to post how I did it.. But I see I already did in that linked thread.. Soo nevermind :)
1 - 8 of 8 Posts
