1 - 1 of 1 Posts
My 09 quite on me yesterday. Was having battery issues , would not hold a charge. Gave it a boost went for a short run, it started to lose power, gauge flashed then it stalled, luck for me it was on my way back. Got a new battery today codes flash in this order, .
Code 52 injector 2 : open load
short circuit to ground
short circuit to battery
code 51 injector 1 : open load
code 22 TPS: open or short circuit to ground
short circuit battery
Started cleaning up ground connections beside battery to frame, is there any other i should check, and / or is there a bigger issue i should be aware of
I am not sure if i put the EFI plugs back together correctly which one has the plug with the wire that has the black stripe coming from the cpu? front or rear injector
I had a dyatek controller hooked up at factory settings, i unhooked it for now problem did not go away.
thanks for the help
tony
Had a loose ground and a blown fuse thinking loose ground made fuse blow ??? but it will run now but code 51 and 52 still come up
Are my enjectors shot?
1 - 1 of 1 Posts
