1 - 2 of 2 Posts
· Registered
Someone please help someone suggested that I have my clutches serviced on a performance problem I'm having so I been reading up on it and to be honest its confusing as heck my rzr is stock except for a uni filter it's a 2010 stealth black I have 26" bighorns on aftermarket wheels. Which clutch Setup should I consider? HELP Please!!!!!!!!!!!
· Registered
Best way to call Dale from DDP and tell him what you are running . He will set you up, my recommendation will be to go with his adjustable weights in case you will add some more power later on. IMHO
And you can check this tread too, in case somebody run set up close to yours.
http://www.rzrforums.net/engine-drivetrain/25089-post-your-great-clutch-setup-here.html
milos
1 - 2 of 2 Posts
