Clutch won't disengage completely
16K views 8 replies 3 participants last post by  Hunterworks
Last weekend riding I sunk my rzr 800s in a creek completely soaking my belt and clutch . It started slipping on me so I drained all the water and everything seemed ok for the rest of the day .
Finally pulled it out of the garage today to wash it and put it in gear and let off the break and it starts moving with no gas also if I hold the break in gear it will start making a terrible squeal . I am no genius but it seems like the clutch is not disengaging as it should . Pulled the cover off the belt /clutch cleaned it with compressed air and it is still doing the same thing ? Any advise or suggestions would greatly be appreciated. There is no way I am taking it to a dealer near me , so I gotta do it myself
Like you suspect, it sounds like the primary is not opening fully, causing the belt to spin.
Sounds like you may have dirt/debris in the primary.
I would pull the primary off the car. Disassemble and clean everything. Make sure the sheaves and weights move freely. Reassemble.
That's a start.
Sent from somewhere over there...
IF bearing only, we have a HD replacement and roughly $150 for bearing, labor and shipping back.
We don't have any other parts like rollers or bushings for it yet, the aftermarket company making them is out until end of the month
Call me at the office in a little while we can talk about it
Todd
Well I got my clutch off today and it seems my bearing is shot , no movement in it what so ever . I think I'm going yo go with your HD replacement hunterworks. But I think I want to try and do it my self . Any suggestions ha ha
