Hofefully you all can help me set up my clutch wieghts for xp900. Have bikemans 935 big bore kit, bored head, cams, intake and throttle bodies and their new intake with power commander 5. Guessing around 115-120 crank hp. Using bikemans stage 2 clutch kit with diff helix, heavier springs and adj weight roosters. Stock is 60 grams, the new roosters alone are 52 grams without any wieghts. The max wieght i can get on the first hole by pin is 7 grams using bolt and washers. (for a total of 59 grams) looking for maximum weight and where to put the weight, from base (pin) to tip??
Setting up to run chokecherry hill at st anthonies, running 9 pdl skats and front mohawks.
What is the rpm where the rzr stops making hp?? I am trying to maintain that rpm while climbing.
I know alot a varieables, but need a starting point, thank
