I just bought an 08 with 1000+mi and Im pretty the clutches have never been touched. It has 26" bighorns all the way around. I raced a friend of mine that also has an 08 but with stock size tires and he walked away from me pretty easily, beating by probably 5 lengths to 30mph. I drove his and the engagement is much smoother, where as mine feels like its slipping then engages. I know with bigger tires my buddy's stock rzr will be faster, but his seemed much faster than mine, all throughout the rpm range. Both rzrs have the spacer removed.
I guess my question is there any rebuild kits out there or which items are wearable components and need to be replaced? Ive read on here that if your rzr is stock a clutch kit is pointless, is it still pointless when you add bighorns? I know I need a new belt, should I get an EPI severe duty or just a Polaris replacement? It is also a PITA to shift into different gears sometimes. I heard that I may need to replace a bearing, do you guys know which one? Sorry for all of the question and thanks in advance for answering them.
