Clutch questions
2.7K views 11 replies 5 participants last post by  Hunterworks
I have done some searching, found some answers still don't have all my answers...
Any clutch gurus in here? I'm thinking my clutch is wore out. 2010 rzr 800s around 8600 miles stock everything as far as I know, it gets up to about 40 mph then very slow to accelerate after that. Rpms around 5600-5800 rpm. Reading it could be the belt, one way bearing, or rollers/ arms. Haven't tore into it yet.
Checking my options I think I just want to install a clutch kit while I'm in there as well as a new belt, one way bearing, and any wear items that I would need to replace while I'm in there.
So, pricing on a clutch kit, one way bearing, wear items, a belt, and a clutch removal tool.
Any suggestions / help?
Todd is a great guy. He will fix you up...
TBS
Hmm. Well heck. Ha. I do have a full hard cab, radio, winch, 27" black waters, an optima yellow top. So I do have some weight. Could a worn belt simply cause this issue? I'm really clueless to this stuff. I just put a new fuel pump and rings in it last winter. Though I didn't do jug or pistons, nor did I do valve guide seals. I'm clueless.
But still....if you have 8600 miles on the original clutches, and haven't take the time to periodically blow the dust and debris out of the clutches...I would bet the primary is badly worn.
I'd inspect it carefully. Todd is a great source for replacements and clutch accessories.
JMHO
Pirate
