I recently decided to change out the belt on my 09 RZR 800. After reading much about the rear clutch cover to engine seal leaking, I decided to pull the primary and secondary and re seal everything.
Now that I have the backing plate of the clutch cover off, the engine side of it is obvious: clean off existing RTV and re-apply new RTV.
On the transmission side, however, it looks as if they use the outer diameter of the input shaft seal to seal to the clutch housing. It's blue like RTV, but it looks like it is actually part of the input shaft seal.
So...what is everyone doing to seal the transmission side? Clean the blue seal and apply silicone grease? Clean the blue portion of the seal and apply RTV over the blue? Remove blue from input shaft seal and apply RTV?
Also, any good way to remove the factory blue RTV from the engine side without damaging the clutch housing?
