Check engine light and code 520207
2 reading
237K views 44 replies 22 participants last post by  185EZ
#1 · (Edited by Moderator)
I checked the diffs today; the front was pretty milky. I changed it out, went for a rip and no prob. Restarted later to pull in the garage and now have this code.
What now?
Hey so when yours was doing this was it not wanting to start and just cranking over forever before it would fire? I have a 2014 xp 1000 and is throwing the same code. It will turn over for ever and after cycling numerous times it will finally fire and once started it runs and idles great. Thanks
Whiskey tango foxtrot!,,
Guys last week I had the 520207-4 code pop up on my 2015 900s. I had no head lights, but had tail lights. But as soon as I turned the light switch on (no light appeared) the engine light would go out. But as soon as I turned the light switch to the off position the engine light would come on. Miraculously a couple days later the engine light is off now. But I took the bike out over the weekend and it overheated on me multiple times. The fan is kicking one and I have plenty of coolant. Is there anyway to code from last week could be causing the bike to overheat? I've already checked and the wire to make sure nothing is pinched...
I'm at a lost if you guys could help me out I'd appreciate it I'm not sure where to go from here. Thanks robby
Open fuse box also. Pull all the fuses and relays.Clean out with electrical cleaner then blow out. Make sure fuse connections are tight. This solved my fan issue that was making mine get hot.
Sent from my SAMSUNG-SM-G928A using Tapatalk
#20 ·
Reviving this thread.
C520207 sub code 4
Came on after repeatedly cranked and no start. Tried started it multiple times 2 days in a row then bought a salamander heater. Finally started 3 days later after I heated the garage to about 80 degrees.
