1 - 10 of 10 Posts
We have a 2017 900 4 and are wanting to change the tire size. Will the 29x14 tires and rims go on without hitting when turning?
I run 30x10x15 on 5+2 rims, fit great, could possibly fit a smaller running 32
I run 30x10-14 Terrabite on STI HD5 Beadlocks Matte Black 14x7 5.0 + 2.0
On Racertech Heavy Springs.
Couldn't get them to rub if i wanted to. I'm ready for 32"s.
I run a lot of pre load. It feels good, mind you I have a bunch of weight.
Also terrebites run about half inch to one inch smaller than advertised.
I also have a lot of extra accessory weight. Bandit dual spring setup all corners, decent preload not a ton. I'm around 14" GC
Hey Gunmaker, I have a 2016 Rzr4 900 that came with the stock 27×11×12 and 27×9×12. I just installed a set of stock 29×11×14 and 29×9×14 off of a 2018 Xp 1000 and they did great on my first ride this past weekend. They didn't rub at all and the extra ground clearance is awesome. I also think they look nicer as well. Hope this helps someone in the future.
What tires are you running? I’ve got the stock 27 dirt commanders on mine but found a set of 29” big horns used on 14s for 450 I want to go look at.
Was running them on my General 4 (Same as a RZR S4) but switched to Tusk 4+3's for a slightly wider stance.
And yes they run a tad small which is why I am going to upgrade to 32's.
Only "lift" is the Shock Therapy RIS2 and SATV 1.5" forward offset A-Arms.
1 - 10 of 10 Posts
