1 - 17 of 17 Posts
I changed my Throttle Body and now getting a 520276 2 and 520276 12 codes, I think the Throttle Pedal and Throttle Body need adjusted. Anyone have this issue before? How did you resolve?
Smooth Moderator
Why did you replace the throttle body? They don't get adjusted and typically don't go bad. I have seen the pedals get dirty or worn causing issues on the drive by wire setups.
Broke the connector that plugs onto it, on the TB. I put a TB from a 1000XP on it. I matched up the wiring etc but maybe need to put an XP tune in it.
Does anyone know how to adjust the Throttle Position Sensor on the XP1000 TB? I am getting , .80 out just .02 out of Spec. I am hoping it is not inside the Black Controller with the Connector on it. I am thinking of loosening that Box and see if I can make a change that way. I really don't want to play with the Butterfly Stop if I don't have too.
Discussion Starter #6
Yes, almost there just need to get the Output down a little, which is a TPS adjustment, the Older 800S had this adjustment. I read that ALBA was working on this at one time?
We never did it, but I do have some insight. Did you change the ecu or harness? This is not a simple swap over. You can not just wire it up. Your stock ECU is not set up for dual throttle bodies and will not operate them correctly...
Nate
Alba Racing
Discussion Starter #8
I moved Pin38 to 37 on Bank One to get the 5VDC Input. I have an XP Tune. Can't you pull 5 VDC from the TMAP to the TB? Everything I have checked they have the same ECU and Everything else. Same Wire Harness except for Pin 37 and 38. 1000S uses Pin38 3.3 VDC and XP Uses Pin37 5 VDC. Right now all I need is get the TPS adjusted and I am set.
Yes, they all use a 5 volt ref. You are using an XP1000 ECU? You can not adjust the TPS. It is adjusted through Digital Wrench only.
Nate
Alba Racing
Discussion Starter #11
I am going to assume that only dealers can get Digital Wrench? The RZR 1000 S uses 3.3V, so do the 900's. So it sounds like I would have to go to the Dealer and have them Adjust it. I will poke around some more before I throw in the Towel and go to the Dealer (There is nothing wrong with my dealer, quite the oppisite). I appreciate your input. I will also be checking out your Web site, see what you guys have.
Discussion Starter #12
I think I found my problem with the Throttle Body(I got it Used). There is a middle gear shaft with a bad bushing on one end. It is a Plastic Bushing, I am going to put a good bushing in it and we will see. The rest of the shafts look OK.
Discussion Starter #13
Throttle Body turned out to be fine. Just had to make a couple adjustments.
I just have to find out what size resister to put on the 02 Sensor Connection then Final Tune. It sounds really good, I did'nt think it would make that much difference (Sound wise). I should have the final tune done tonight, let you know how much difference it makes (Power wise).
Discussion Starter #14
I have been running for a few weeks now and it is running great. Just ordered XP Cams should have them on next week for the last race of the Season. Does anyone with a BULLYDOG know what Throttle Percentage is at at:
1. Key on but not started for about 15 seconds?
2. Running at Idle?
I just want to make sure I have it set correct.
Thanks
i also sent a PM just hoping you see notification for one of them. any help would be great!
i have read your post few times and finally swapped my single TB setup for the dual. but im getting same adaption issue you had. i had dynojet overlay the xp1000 tune onto my ecu. only code i get is adaption. i did swap the wire over from pin 38 to 37 and that actually got it running at idle. the power vision does not seem to have TPS adjustment as a option in the tuning.
please any insight would be huge help
thanks!
1 - 17 of 17 Posts
