Looking for some help connecting the carb. I have the fuel line hooked up and the other smaller line that connects on the back. But I can not figure out where the other end of that line connects too. Any help please
Ok I figured it out. The left bottom neck goes to the fuel pump vac. The top neck hose to the egr that goses to the exhaust. The right on the carb goes to the fuel/fuel filter and there is another next to that it dosnt go to anything.
Broccoli2, I've got everything back together and now I'm having problems getting fuel to the carb. I got a new fuel pump and fuel filter and the lines cleaned. Is there something special to get it going? Dose fuel have to be in the lines to get it pumping? I put fuel in the carb bowl and it would run for a couple of minutes then stop because it isn't getting any fuel from the pump. Any suggestions? Thanks!
I actually had the same problem for about an hour. The. I realized I turned off the gas when I took mine apart. The petcock is on the pass side just below the back of the door opening.
The only other simple thing and it sounds like you would have checked this but make sure all your lines are hooked up correctly and that you don't have any pinched or kinked lines. You can always put fuel back in the bowl and see if the vacuum line is sucking. i would bet you either have a bad pump, lines are hooked up wrong, or you have bad lines (cracks holes etc.)
Ok I will double check everything when I get home and could take some pictures to make sure I have the lines hooked up correctly. The fuel pump is new but new dosnt mean it will always work. The vacuum line should be connected to the lower fitting on the carb neck correct?
